Lay product flat on a clear and clean surface.
As this is a teardown, we want to minimise the risk of any injuries. Firstly, ensure all PPE is warn including gloves and face shield. Next, cut the power cable to prevent in-proper reassemble.
Open up the product.
Use a Philips-Head Screwdriver to remove these 4 screws.
The plate can then be removed.
Remove the 2 highlighted screws at the top of the heating plate.
Flip up the Base Heating Plate from casing to reveal internal wires.
Remove the 3 highlighted screws.
Use wire cutters to snip the connecting wires to the heating element.
Flip product over so the bottom is facing upwards.
Remove the 2 highlighted screws.
Slide out the black cover. Keeping in mind there is a tab on the left hand side.
After removing the wire casing, gently pull on the wires and feed them through the hole. It should come out as a whole unit.
Simply pinch and squeeze each silicone foot to remove from the outer shell.
Open up the product and lay flat on the top side
Repeating Step#3, use a Philips Head screwdriver to remove the 4 screws that are highlighted.
Remove the 2 highlighted screws on the Top Heating plate.
Close the Top Heating Plate, leaving the outer case laying on the bench.
Once screws have been removed, gently wiggle and dislodge the thermostat.
NOTE: There will be a layer of thermal paste between the thermostat and heating plate. Grab an old rag to wipe off.
Once the thermostat has been removed, gently grab the heat shield cover and remove.
Pinch and slide up the 2 highlighted silicone stoppers.
Once stoppers have been removed, apply slight force the remove the LED's from respected colours.
Pinch the extrusions of the coloured diffuser and apply slight downward force to remove via the outer side of the product.
NOTE: Arrows indicate where to pinch.
This is a snap fit piece. Apply slight pressure to one side of the clip and work one side first to pop off from the casing.
The outer casing can now be fully separated from the heating plates.
Either use pliers to remove the solder between the wires and the heating element.
Or
Use wire cutters to snip the wires as completed in Step#6.
Simply apply an angle to both heating elements and release from the hinge connection.
