Introduction
In this guide, users will learn about some of the internal workings of some older lamps. The lamp in this guide is actually a lamp from my grandmother. It was one of her favorite lamps for its unique patterns it throws on the room around it. It's a simple replacement of the threaded center support that just requires a bit of disassembly to get to it, once that is all done the lamp is reassembled the same way it came apart.
Ce dont vous avez besoin
Start by unscrewing the decorative nut from the top of the canopy. Then lift the canopy off the old support.
When the canopy is removed from the lamp, lift the broken support off. The wires should now be accessible from the top.
Save these pieces, as they might be useful in reassembly.
Mark the positive wire on the main power cord; this can be done with a marker, tape, or most any other method.
The threaded rod and coupling may need a hole for the wires to pass through. Remove the coupling and rod from the light fixture; do not move the coupler up the threaded rod. The coupler's location will serve as a reference for the hole.
Make a hole with the drill; if the size of the whole needed is unknown, a stepped drill bit is useful. Do not apply too much pressure as the metal is likely soft.
