Aller au contenu principal
Aoson R103 Speakers Replacement
Ce dont vous avez besoin
  1. Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: étape 1, image 1 de 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: étape 1, image 2 de 3 Aoson R103 Speakers Replacement, Aoson R103 Opening and Disassembly: étape 1, image 3 de 3
    • Turn off the device using the power button.
    • Using fingernails/a pry tool, separate the back panel of the device. This may decent force as they are connected by push tabs.
    • Be careful not to drop the device when separating, this could cause permanent damage.
    • This will expose the motherboard of the device.
  2. Aoson R103 Speakers Replacement: étape 2, image 1 de 2 Aoson R103 Speakers Replacement: étape 2, image 2 de 2
    • Use your fingers to unclip the ribbon connecter and then pull the ribbon out of the connector.
    • This ribbon connects the power button and stops the device from turning on; allowing further procedure.
  3. Aoson R103 Speakers Replacement, Speakers: étape 3, image 1 de 3 Aoson R103 Speakers Replacement, Speakers: étape 3, image 2 de 3 Aoson R103 Speakers Replacement, Speakers: étape 3, image 3 de 3
    • The motherboard connections to the speaker are circled, they will be needed later.
    • The two speakers are circled in orange, they are attached to a plastic piece via a screw.
    • The 4.0mm long philips-head 00 screw will be disconnected at the Boxed area where the plastic disconnects.
    • Be careful not to disconnect the back ground wire when taking the plastic off.
  4. Aoson R103 Speakers Replacement: étape 4, image 1 de 2 Aoson R103 Speakers Replacement: étape 4, image 2 de 2
    • The box contains the four (4) soldering connections for the two speakers. Unsolder the old speakers and solder the new speakers in.
    • Be sure to match up the appropriately placed speaker to its correct positive or negative node. mixing these up could distort audio or fry the speakers.
    • Note: solder over a piece of paper where you can mark each node with a red or black marker to denote positive and negative nodes for the left or right speaker.
Louis
Membre depuis le 02/14/23
208 Réputation
2 tutoriels rédigés
Équipe
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 16
Total : 174
