Aller au contenu principal
Apalus Digital Hair Straightening Brush Buttons Replacement
Ce dont vous avez besoin
  1. Apalus Digital Hair Straightening Brush Buttons Replacement, Buttons on the side of the brush: étape 1, image 1 de 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 2, image 1 de 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 3, image 1 de 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 4, image 1 de 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 5, image 1 de 1
    • Locate the three buttons on the bottom side of the circuit board.
  6. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 6, image 1 de 1
    • Each button is soldered in four places on the circuit board. Using the soldering tool, melt each of these four points and remove the dysfunctional buttons.
    • You may have to bend the dark red capacitor out of the way to reach the soldering points.
    • Soldering Technique Guide
  7. Apalus Digital Hair Straightening Brush Buttons Replacement: étape 7, image 1 de 1
    • Now that the dysfunctional buttons are removed, use a soldering tool and solder to install the new buttons on the circuit board.
    • Solder at the same four points as when previously melting these points to remove the buttons.
Aaron Brysch
Membre depuis le 11/06/17
231 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team S1-G3, Harley Fall 2017 Membre de l'équipe IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 17
Total : 671
