Aller au contenu principal
Apalus Digital Hair Straightening Brush LCD Screen Replacement
Ce dont vous avez besoin
  1. Apalus Digital Hair Straightening Brush LCD Screen Replacement, LCD Screen: étape 1, image 1 de 1
    • Remove the seven 5mm Phillips #1 screws on the comb-side of the brush.
  2. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 2, image 1 de 1
    • Now that the screws are taken out, remove the backside of the comb.
  3. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 3, image 1 de 1
    • Unplug the power cord from the insert inside of the brush.
    • Be careful not to tug on the wires. Hold the insert when removing the power cord.
  4. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 4, image 1 de 1
    • Remove the circuit board and heating element from the handle.
    • This will make it easier to work on for later steps.
  5. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 5, image 1 de 1
    • Locate the LED screen on the top side of the circuit board
  6. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 6, image 1 de 1
    • Flip the circuit board to start soldering.
  7. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 7, image 1 de 2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 7, image 2 de 2
    • Using the soldering tool, melt the solder holding the LCD screen on the circuit board.
    • The screen is soldered in 11 places on the circuit board. Melt each of these points and remove the screen.
    • Soldering Technique Guide
  8. Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 8, image 1 de 2 Apalus Digital Hair Straightening Brush LCD Screen Replacement: étape 8, image 2 de 2
    • Now that the LCD screen is removed, use a soldering tool and solder to install the new screen on the circuit board.
    • Solder at the same 11 points where you previously melted to remove the screen.
Malak
Membre depuis le 11/06/17
101 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S1-G3, Harley Fall 2017 Membre de l'équipe IUPUI, Team S1-G3, Harley Fall 2017
IUPUI-HARLEY-F17S1G3
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 3
7 derniers jours : 7
30 derniers jours : 18
Total : 518
