Aller au contenu principal
Apex TM772 Rear Camera Replacement
Ce dont vous avez besoin
  1. Apex TM772 Rear Camera Replacement, Rear Camera: étape 1, image 1 de 1
    Outil utilisé dans cette étape :
    J'achète
    • The rear facing camera is located at the top right just below the front facing camera as looking inside the device.
    • With tweezers or your fingers remove the tape covering the camera’s pin connector.
  2. Apex TM772 Rear Camera Replacement: étape 2, image 1 de 1
    • With tweezers, flip the black latch to open the pin connector and remove the cable.
    • The camera is adhered to the device with double sided foam tape. Carefully remove the camera from the tape with a metal spudger. If the tape is damaged, you’ll need to replace it.
    • Replace the camera with the new one and assemble the device in reverse of these instructions.
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 7
Total : 84
