Introduction
This is another guide that will be used for several repairs. The logic board is the most frequently replaced part for this device as individual parts are hard to come by.
Ce dont vous avez besoin
Slowly peel off the rubber pad on the bottom of the device. Start from one corner and peel with your fingers. Use heat if necessary until pad is completely removed.
After removing the rubber pad, unscrew the five 5mm phillips #00 screws in the holes of the back cover.
Remove logic board and metal casing from outer case by prying from one side using a spudger.
Unhook the wires connecting the logic board to the metal casing by grabbing and pulling up on each connection with tweezers.
Carefully push back the three metal tabs with your fingers on the sides of metal case.
3 autres ont terminé cette réparation.
Un commentaire
my apple a1143 wont turn on at all no light.
what can it be done?
