Introduction
If the base station does not turn on, the battery may need to be replaced.
Ce dont vous avez besoin
First start by peeling off the outer rubbery covering on the bottom of the device.
Remove the metal casing by gently prying the logic board away with you hands.
This should be pretty easy, you already removed the screws holding these pieces together.
7 autres ont terminé cette réparation.
5 commentaires
Hi! How to know i need to change battery? What the symptoms of dead battery? My Airport Extreme worked well 6 years, and now its have the problems, missing pings, can it be symptom of dead battery?
I have an A1354 and it powers up just fine. The problem is that it keeps dropping connection to airport utility on my mac every 5 seconds or so. I came here looking for a potential diagnosis/repair. I didn’t know about the battery. Could that be an issue? It has never been replaced.
