Introduction
Cela montrera comment démonter le boîtier extérieur de l'appareil afin que les réparations puissent être effectuées.
Ce dont vous avez besoin
Commencez d'abord par décoller le revêtement caoutchouteux extérieur au bas de l'appareil.
Retirez l'enveloppe extérieure.
La carte logique exposée devrait ressembler à ceci.
Remove the 3 connectors from the logic board to the antennas before removing the logic board from the metal surround.
Pour remonter votre appareil, suivez ces instructions dans l'ordre inverse.
3 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
[deleted] nous aide à réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
By the time I needed to open my AirPort Extreme in mid-2019, the adhesive bond to the covering had weakened to the point that the covering readily peeled away cleanly without the application of heat. I just worked slowly and carefully.
The covering had no residue of adhesive on it after removal, but there was a sheet of adhesive clinging to the plastic surface of the body of the unit. I had to poke holes in it to reach the screws, but that was no big deal and easily done.
When finished, the rubbery covering adhered to the body of the unit again adequately without the use of additional adhesive or (as I had planned to use) double-sided tape.
BTW I was not disassembling the unit to replace the battery, but rather to reset the device by bridging the contacts that a broken reset switch failed to connect. (The switch had become detached from the circuit board and was literally hanging by a thread when I opened the case and fell off altogether as I examined it.)
Thanks for the clear disassembly instructions!
gambaguru+fb - Réponse
When I performed this, the rubber had deteriorated(?) and tore quite easily, particularly around the model number label.
Steve I - Réponse
