Aller au contenu principal
Apple EarPods Disassembly
Ce dont vous avez besoin
  1. Apple EarPods Disassembly, Tools You Need: étape 1, image 1 de 2 Apple EarPods Disassembly, Tools You Need: étape 1, image 2 de 2
    • X-ACTO Knife
    • Tweezer
    • Triangle Paddle
    • Alcohol
    • Cotton Swabs
  2. Apple EarPods Disassembly, Opening Earpod: étape 2, image 1 de 2 Apple EarPods Disassembly, Opening Earpod: étape 2, image 2 de 2
    • Using a triangle paddle, apply sufficient pressure to get in-between the opening section
  3. Apple EarPods Disassembly, Cleaning Inside and Out: étape 3, image 1 de 1
    • Soak one side of a cotton swab with alcohol
    • Clean inner and outer pod using swab soaked in alcohol
  4. Apple EarPods Disassembly, Cleaning the Speaker Cone: étape 4, image 1 de 1
    • Carefully clean the speaker cone using cotton swab
    • Once clean, reattach the earbud
  5. Apple EarPods Disassembly, Removing the Grill: étape 5, image 1 de 2 Apple EarPods Disassembly, Removing the Grill: étape 5, image 2 de 2
    • Carefully remove grill out of both earbuds using tweezers
    • Take precautions not to bend grill excessively
  6. Apple EarPods Disassembly, Grill Polishing: étape 6, image 1 de 1
    • Clean grill with cotton swab soaked in alcohol
    • Remove any build up of wax or sweat
  7. Apple EarPods Disassembly, Placing Grill Back: étape 7, image 1 de 2 Apple EarPods Disassembly, Placing Grill Back: étape 7, image 2 de 2
    • Once the grill is clean, place the grill back inside of the apple earbuds
To reassemble your device, follow Step 7, Step 4 and Step 2 instructions in reverse order.
7 autres ont terminé cette réparation.
Eduardo Gonzalez
Membre depuis le 10/31/18
365 Réputation
1 tutoriel rédigé
Un commentaire
When I re assemble they won’t stay closed. Do I glue them back together?
Patrick Appleby - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 20
7 derniers jours : 129
30 derniers jours : 614
Total : 41,019
