Aller au contenu principal
Apple Extended Keyboard A1243 Key Replacement
Ce dont vous avez besoin
  1. Apple Extended Keyboard A1243 Key Replacement, Key: étape 1, image 1 de 1
    • Place the keyboard on a flat surface.
  2. Apple Extended Keyboard A1243 Key Replacement: étape 2, image 1 de 1
    • Inspect the key that is stuck or the key mechanism where the missing key was.
  3. Apple Extended Keyboard A1243 Key Replacement: étape 3, image 1 de 2 Apple Extended Keyboard A1243 Key Replacement: étape 3, image 2 de 2
    • If the key is stuck, gently insert a spudger under the edge of the keycap.
    • Start from one corner and carefully pry the keycap from the keyboard, working your way around it until it pops out.
    • Inspect the key mechanism (scissor switch under the keycap) for any damage or debris.
    • If the keycap is dirty, clean it by soaking it in warm soapy water.
    • Ensure the key mechanism and cap are dry before reassembling.
  4. Apple Extended Keyboard A1243 Key Replacement: étape 4, image 1 de 2 Apple Extended Keyboard A1243 Key Replacement: étape 4, image 2 de 2
    • If the mechanism is damaged, you will need to replace it.
    • Install the new or previously removed key by aligning the keycap with the key mechanism. Align the top of the scissor-switch to the metal notches on the keyboard and then align the bottom of the switch, ensuring you hook the scissor-switch onto the metal tab on the keyboard.
    • Press down firmly on the keycap until it snaps into place.
  5. Apple Extended Keyboard A1243 Key Replacement: étape 5, image 1 de 1
    • Test the key by plugging in or turning the keyboard on to see if it works correctly.
Ligne d'arrivée
Laura Caucci
Membre depuis le 01/13/25
121 Réputation
1 tutoriel rédigé
Équipe
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 7
7 derniers jours : 47
30 derniers jours : 270
Total : 1,440
