Aller au contenu principal
Apple IIc Keyboard Replacement
Ce dont vous avez besoin
  1. Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: étape 1, image 1 de 2 Apple IIc Keyboard Replacement, Disassembling Apple IIc Cover: étape 1, image 2 de 2
    • Remove the six 19 mm long screws with a #2 Phillips head screwdriver.
  2. Apple IIc Keyboard Replacement: étape 2, image 1 de 2 Apple IIc Keyboard Replacement: étape 2, image 2 de 2
    • Release the catch by pushing it in using a plastic opening tool.
    • The catch is off-center, but in line with the middle of the speaker underneath.
  3. Apple IIc Keyboard Replacement: étape 3, image 1 de 2 Apple IIc Keyboard Replacement: étape 3, image 2 de 2
    • Slide the case toward the ports on the back, then grip under the catch and pull up while moving toward the ports to remove.
  4. Apple IIc Keyboard Replacement: étape 4, image 1 de 2 Apple IIc Keyboard Replacement: étape 4, image 2 de 2
    • Lift the handle straight up to remove.
  5. Apple IIc Keyboard Replacement, Keyboard: étape 5, image 1 de 2 Apple IIc Keyboard Replacement, Keyboard: étape 5, image 2 de 2
    • Tilt the keyboard up while detaching the ribbon connection by pulling it straight up. You may have to wiggle the connector sideways to loosen it.
    • Be careful not to force the ribbon while pulling it out to avoid tearing. Do not try to pull the ribbon out by pulling the keyboard as it may cause tearing.
4 autres ont terminé cette réparation.
Alexandria Weinberg
Membre depuis le 10/06/11
601 Réputation
3 tutoriels rédigés
Équipe
Cal Poly, Team 21-23, Maness Fall 2011 Membre de l'équipe Cal Poly, Team 21-23, Maness Fall 2011
CPSU-MANESS-F11S21G23
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 14
Total : 3,395
