Aller au contenu principal
Apple Lisa Disassembly
Ce dont vous avez besoin
  1. Apple Lisa Disassembly, Prepare Workspace: étape 1, image 1 de 1
    • Place the Lisa on a safe/sturdy surface.
  2. Apple Lisa Disassembly, Removing Front Panel: étape 2, image 1 de 2 Apple Lisa Disassembly, Removing Front Panel: étape 2, image 2 de 2
    • Press the two tabs underneath to release the panel.
  3. Apple Lisa Disassembly, Remove Drive Cage: étape 3, image 1 de 1
    • Release the thumbscrew underneath the drive cage and the cage will pull out. Disconnect drive wires while the cage is being removed.
  4. Apple Lisa Disassembly, Remove Back Panel: étape 4, image 1 de 2 Apple Lisa Disassembly, Remove Back Panel: étape 4, image 2 de 2
    • Twist thumbscrews on the back to release the panel. Pull panel up to remove.
  5. Apple Lisa Disassembly, Remove Power Supply: étape 5, image 1 de 3 Apple Lisa Disassembly, Remove Power Supply: étape 5, image 2 de 3 Apple Lisa Disassembly, Remove Power Supply: étape 5, image 3 de 3
    • Release the thumbscrew on the power supply. Pull out the power supply.
  6. Apple Lisa Disassembly, Remove Cardcage: étape 6, image 1 de 2 Apple Lisa Disassembly, Remove Cardcage: étape 6, image 2 de 2
    • Grab the card cage at the location shown and pull out.
  7. Apple Lisa Disassembly, Remove Top: étape 7, image 1 de 2 Apple Lisa Disassembly, Remove Top: étape 7, image 2 de 2
    • Unscrew two philips screws on the ceiling of where the card cage was.
  8. Apple Lisa Disassembly, Remove Power Switch: étape 8, image 1 de 2 Apple Lisa Disassembly, Remove Power Switch: étape 8, image 2 de 2
    • Release two screws and release the ribbon cable.
  9. Apple Lisa Disassembly, Remove Right Panel: étape 9, image 1 de 3 Apple Lisa Disassembly, Remove Right Panel: étape 9, image 2 de 3 Apple Lisa Disassembly, Remove Right Panel: étape 9, image 3 de 3
    • Remove all screws shown.
  10. Apple Lisa Disassembly, Remove Left Panel: étape 10, image 1 de 2 Apple Lisa Disassembly, Remove Left Panel: étape 10, image 2 de 2
  11. Apple Lisa Disassembly, Remove Feet Panel: étape 11, image 1 de 1
  12. Apple Lisa Disassembly, Remove Bottom Pannel: étape 12, image 1 de 1
  13. Apple Lisa Disassembly, CRT: étape 13, image 1 de 1
    • I am not a certified CRT technician so I am not suppling steps on how to remove it although here is a photo of the innards.
  14. Apple Lisa Disassembly, Remove Cards: étape 14, image 1 de 3 Apple Lisa Disassembly, Remove Cards: étape 14, image 2 de 3 Apple Lisa Disassembly, Remove Cards: étape 14, image 3 de 3
    • Pull up on the tabs to remove cards.
  15. Apple Lisa Disassembly, Remove Card Mount: étape 15, image 1 de 3 Apple Lisa Disassembly, Remove Card Mount: étape 15, image 2 de 3 Apple Lisa Disassembly, Remove Card Mount: étape 15, image 3 de 3
4 autres ont terminé cette réparation.
LisaGuide
Membre depuis le 12/30/18
1 833 Réputation
11 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 26
Total : 2,092
