Aller au contenu principal
Apple Magic Keyboard 2 A2450 Keyboard Replacement
Ce dont vous avez besoin
  1. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: étape 1, image 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: étape 1, image 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Lower Case: étape 1, image 3 de 3
    • Apply heat around the perimeter of the lower case to loosen the adhesive that secures the lower case to the chassis.
    • The plastic should be a bit too warm to touch comfortably, but not hot.
    • Insert an opening pick in the gap between the lower case and chassis.
    • After ensuring that the adhesive is warm, slide the pick around the perimeter to sever the adhesive.
    • As you sever the adhesive, insert additional opening picks at each corner to prevent the adhesive from readhering.
    • Remove the lower case.
  2. Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: étape 2, image 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: étape 2, image 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement, Keyboard: étape 2, image 3 de 3
    • Use a T3 Torx screwdriver head to remove all twelve 5 mm that secure the midframe.
    • Use tweezers to disconnect the battery motherboard connection.
    • Remove the midframe.
  3. Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 3, image 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 3, image 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 3, image 3 de 3
    • Use a T3 Torx screwdriver to remove the two 5 mm screws that secure the lightning port.
    • Use tweezers to remove the Lighting port from the motherboard.
  4. Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 4, image 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 4, image 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 4, image 3 de 3
    • Use a T3 Torx screwdriver to remove the three 3 mm screws that secure the motherboard.
    • Remove the tape covering the ribbon cable on the top half of the motherboard.
    • Use a small pair of tweezers to gently unplug the ribbon cable and remove the motherboard from the keyboard.
  5. Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 5, image 1 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 5, image 2 de 3 Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 5, image 3 de 3
    • Use a T3 Torx screwdriver to remove the single 3 mm screw that secures the assembly to the frame.
    • Use tweezers to unplug the power switch from the case. Pull horizontally on the entire assembly to remove the switch from the keyboard.
  6. Apple Magic Keyboard 2 A2450 Keyboard Replacement: étape 6, image 1 de 1
    • Replace the keyboard.
Alex
Membre depuis le 04/02/24
219 Réputation
2 tutoriels rédigés
Équipe
IUPUI, Team 3-2, Harley Spring 2024 Membre de l'équipe IUPUI, Team 3-2, Harley Spring 2024
IUPUI-HARLEY-S24S3G2
4 membres
3 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 12
7 derniers jours : 31
30 derniers jours : 181
Total : 2,081
