Ce dont vous avez besoin
Remove the batteries.
Remove the plastic cover on the bottom. (On older models, this cover is not centered.)
Remove the small screw.
Take the keyboard out of the liquid and shake it out well.
CAUTION!! This step is not absolutely necessary!! Opening the keyboard further is only necessary if you want to gain access to the circuit paths.
The plastic cover on the back can now be easily detached. To do this, use a flat blunt tool to go into the gap and pry off the plastic cover. The alcohol has softened the glue.
Let the keyboard dry well. To speed up the process, you can put it into the sun.
2 autres ont terminé cette réparation.
Merci à ces traducteurs :
100%
Ces traducteurs nous aident réparer le monde ! Vous voulez contribuer ?
Commencez à traduire ›
