Aller au contenu principal
Apple PowerBook G3 400 Display Replacement
Ce dont vous avez besoin
  1. Apple PowerBook G3 400 Display Replacement, Keyboard: étape 1, image 1 de 1
    • Pull the keyboard tabs toward you while lifting up on the keyboard until it releases from it's hold.
    • To lift the keyboard out pull it up and away from you. Then place the keyboard on the track pad.
  2. Apple PowerBook G3 400 Display Replacement: étape 2, image 1 de 1
    • Pull the keyboard ribbon vertically from the logic board to release connection.
    • The connector may be tight and difficult to remove. If stuck try rocking the connector back and forth while pulling up until it releases. This same process can be used for many of the connectors on this device.
    • Remove battery and CD/DVD drives before proceeding any further.
  3. Apple PowerBook G3 400 Display Replacement: étape 3, image 1 de 1
    • Your computer should look approximately like this.
  4. Apple PowerBook G3 400 Display Replacement, RAM: étape 4, image 1 de 1
    • Remove the two silver Phillips #1 screws that attach the heat shield to the metal framework.
    • Lift the heat shield up and toward you.
  5. Apple PowerBook G3 400 Display Replacement: étape 5, image 1 de 1
    • Pull the PRAM battery cable vertically upward to disconnect it.
    • Remove the battery by pulling up and to the left.
  6. Apple PowerBook G3 400 Display Replacement: étape 6, image 1 de 1
    • Remove the two T8 Torx screws that attach the heat sink to the processor.
    • Remove the long silver Phillips #1 screw from the heat sink.
  7. Apple PowerBook G3 400 Display Replacement: étape 7, image 1 de 1
    • Lift up the heat sink unit from the left side and remove.
  8. Apple PowerBook G3 400 Display Replacement: étape 8, image 1 de 1
    • Lift the processor on the right side and pull directly up.
    • The RAM chips should be in the slots on the processor.
  9. Apple PowerBook G3 400 Display Replacement: étape 9, image 1 de 1
    • After removing the RAM, your laptop should now look like this.
  10. Apple PowerBook G3 400 Display Replacement, Hard Drive: étape 10, image 1 de 1
    • Locate the orange tab, which should be just left of the hard-drive.
    • You must disconnect this orange tab from the logic board to enable the next step.
    • It is better to do this by grabbing the plastic connection point, not the relatively flexible cable.
  11. Apple PowerBook G3 400 Display Replacement: étape 11, image 1 de 1
    • Grab the plastic strip shown here and gently remove, pulling up and left.
    • Pull left to avoid the hard drive catching the casing.
  12. Apple PowerBook G3 400 Display Replacement: étape 12, image 1 de 1
    • Once you have removed the hard-drive, your laptop should like this.
  13. Apple PowerBook G3 400 Display Replacement, Modem: étape 13, image 1 de 1
    • Remove the single black Torx screw from the modem.
    • Remove the black rectangle that is being held on by the one Torx screw.
  14. Apple PowerBook G3 400 Display Replacement: étape 14, image 1 de 1
    • Using your fingers, lift the modem from the socket it is plugged into.
  15. Apple PowerBook G3 400 Display Replacement: étape 15, image 1 de 1
    • Disconnect the cable that is attached to the end of the modem to remove the modem.
  16. Apple PowerBook G3 400 Display Replacement, Display: étape 16, image 1 de 1
    • Your computer will look approximately like this.
  17. Apple PowerBook G3 400 Display Replacement: étape 17, image 1 de 1
    • Push the display back.
    • Put your index finger under the power button and gently pull the clutch cover back.
    • Repeat for the left side.
  18. Apple PowerBook G3 400 Display Replacement: étape 18, image 1 de 1
    • Lift the clutch cover up and off. Pull it towards yourself.
  19. Apple PowerBook G3 400 Display Replacement: étape 19, image 1 de 1
    • Disconnect the display cable from the logic board.
  20. Apple PowerBook G3 400 Display Replacement: étape 20, image 1 de 1
    • Remove the Torx screw that holds the display cable.
    • Pull out thick display inverter board by pulling it up and out. Two tabs will be holding it in place, you need to get pass these to pull the board free.
  21. Apple PowerBook G3 400 Display Replacement: étape 21, image 1 de 1
    • Disconnect the white inverter cable. Pull it towards the left.
  22. Apple PowerBook G3 400 Display Replacement: étape 22, image 1 de 1
    • Disconnect the inverter plug by pulling it up from the logib board.
  23. Apple PowerBook G3 400 Display Replacement: étape 23, image 1 de 1
    • Turn the laptop around.
    • Open the port door.
    • Remove the four Torx screws.
  24. Apple PowerBook G3 400 Display Replacement: étape 24, image 1 de 1
    • Turn the laptop so the front faces you.
    • Pull the black Airport antenna up.
  25. Apple PowerBook G3 400 Display Replacement: étape 25, image 1 de 1
    • Pull the display up as you hold it firmly with both hands.
Isabelle
Membre depuis le 04/18/11
11 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 4-2, Regan Spring 2011 Membre de l'équipe Cal Poly, Team 4-2, Regan Spring 2011
CPSU-REGAN-S11S4G2
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 14
Total : 1,714
