Aller au contenu principal
Apple Powerbook 520 Floppy Drive Replacement
Ce dont vous avez besoin
  1. Apple Powerbook 520 Floppy Drive Replacement, Floppy Drive: étape 1, image 1 de 1
    • With the Generally Disassembly completed, you may proceed to floppy drive installation.
  2. Apple Powerbook 520 Floppy Drive Replacement: étape 2, image 1 de 1
    • Remove the plastic panel at the bottom of the display.
  3. Apple Powerbook 520 Floppy Drive Replacement: étape 3, image 1 de 1
    • Reverse the computer to access the peripheral panel in the back.
    • Remove the two T8 Torx screws on either side of the bar code panel.
  4. Apple Powerbook 520 Floppy Drive Replacement: étape 4, image 1 de 1
    • Reverse the computer to have the monitor and mousepad facing you.
    • Remove the plastic panel underneath the display.
  5. Apple Powerbook 520 Floppy Drive Replacement: étape 5, image 1 de 1
    • Remove the three T8 Torx screws securing the floppy drive to the frame.
  6. Apple Powerbook 520 Floppy Drive Replacement: étape 6, image 1 de 1
    • Using a spudger, lift the plastic tabs on the floppy drive securing the ribbon cable to the ribbon port.
  7. Apple Powerbook 520 Floppy Drive Replacement: étape 7, image 1 de 1
    • Lift the defective floppy drive from the body of the computer.
  8. Apple Powerbook 520 Floppy Drive Replacement: étape 8, image 1 de 1
    • Replace the defective drive with a new drive.
    • Follow these instructions in reverse order to reassemble the device.
2 autres ont terminé cette réparation.
Kevin Peters
Membre depuis le 04/19/11
130 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team 20-66, Walters Spring 2011 Membre de l'équipe Cal Poly, Team 20-66, Walters Spring 2011
CPSU-WALTERS-S11S20G66
4 membres
3 tutoriels rédigés
Un commentaire
Does anyone know where I can actually find another FDD for this PowerBook? Because I think i broke mine ((
Ali Sadykov - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 3
30 derniers jours : 8
Total : 2,712
