Aller au contenu principal
Apple Powerbook 520/540 General Disassembly
Ce dont vous avez besoin
  1. Apple Powerbook 520/540 General Disassembly, Case: étape 1, image 1 de 2 Apple Powerbook 520/540 General Disassembly, Case: étape 1, image 2 de 2
    • Turn computer over.
    • Remove battery expansion cover and battery.
  2. Apple Powerbook 520/540 General Disassembly: étape 2, image 1 de 1
    • With monitor hinge at the bottom, remove the two top center screws.
    Not necessary for RAM, hard drive, or CPU replacement.
    Miles Raymond - Réponse
    The Screws are T8!
    Willy Kaiser - Réponse
  3. Apple Powerbook 520/540 General Disassembly: étape 3, image 1 de 1
    • Remove top left and top right screws.
    Also not necessary for RAM, hard drive, or CPU replacement.
  4. Apple Powerbook 520/540 General Disassembly: étape 4, image 1 de 1
    • Remove middle left and middle right screws.
  5. Apple Powerbook 520/540 General Disassembly: étape 5, image 1 de 1
    • Open computer kickstands.
    • Remove screws underneath each kickstand.
    Again not necessary for RAM, hard drive, or CPU replacement.
    Philips PH00 screws
    8-Bit Hero Wendler - Réponse
  6. Apple Powerbook 520/540 General Disassembly: étape 6, image 1 de 1
    • Lift keyboard from bottom and take out of shell.
  7. Apple Powerbook 520/540 General Disassembly: étape 7, image 1 de 3 Apple Powerbook 520/540 General Disassembly: étape 7, image 2 de 3 Apple Powerbook 520/540 General Disassembly: étape 7, image 3 de 3
    • Lift the white ribbon clamps securing the keyboard ribbon cables to the motherboard. You can do this using a plastic opening tool.
    • Removing both ribbon cables from the motherboard will leave the clamps like so.
    • From here you can access the logic board, hard drive, and floppy drive.
9 autres ont terminé cette réparation.
Mark McNeff
Membre depuis le 04/20/11
497 Réputation
2 tutoriels rédigés
2 commentaires
http://tim.id.au/laptops/apple/powerbook... (PDF)
Apple Service Source: PowerBook 500 Series
Guides for everything.
tas - Réponse
Thanks been trying to fix this for a long time
Luke - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 11
30 derniers jours : 48
Total : 6,684
