Aller au contenu principal
Apple Powerbook 5300 Display Replacement
Ce dont vous avez besoin
  1. Apple Powerbook 5300 Display Replacement, Battery: étape 1, image 1 de 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Display Replacement, Keyboard: étape 2, image 1 de 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Display Replacement: étape 3, image 1 de 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Display Replacement, Display: étape 4, image 1 de 3 Apple Powerbook 5300 Display Replacement, Display: étape 4, image 2 de 3 Apple Powerbook 5300 Display Replacement, Display: étape 4, image 3 de 3
    • Begin by locating the side panel covers.
    • Remove the side panels by pulling up and towards the rear of the laptop.
    • Remove the two Torx #8 screws using a TR8 Torx security screwdriver.
    • You need to remove the screws from the left and right side panels.
  5. Apple Powerbook 5300 Display Replacement: étape 5, image 1 de 2 Apple Powerbook 5300 Display Replacement: étape 5, image 2 de 2
    • Turn the laptop upside down.
    • Remove the three Torx #8 screws.
    • Turn the laptop right side up, then lift up the keyboard.
  6. Apple Powerbook 5300 Display Replacement: étape 6, image 1 de 2 Apple Powerbook 5300 Display Replacement: étape 6, image 2 de 2
    • Disconnect the ribbon cable from the logic board.
    • Potential for device damage: The cable is twisted around the monitor hinge, so do not pull up. Unravel the cable from the hinge first.
  7. Apple Powerbook 5300 Display Replacement: étape 7, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 7, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 7, image 3 de 3
    • Use a pin to pry up the Powerbook 5300 and Macintosh logos to reveal two screws.
    • Using a spudger, remove the two product nameplates to expose the underlying screws.
    • Remove two Torx #8 screws.
    • Be care when using the spudger not to break the tabs on the nameplates.
  8. Apple Powerbook 5300 Display Replacement: étape 8, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 8, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 8, image 3 de 3
    • Remove the four screws holding the bezel to the back display housing.
    • Turn the display face down with the Apple logo facing towards you.
    • Starting at the bottom of the display housing, carefully pry the plastics apart at the six inner latch locations using a spudger.
  9. Apple Powerbook 5300 Display Replacement: étape 9, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 9, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 9, image 3 de 3
    • Use a prying tool to open the two halves of the display assembly.
    • Lift the top half away from the bottom half to expose the inverter board.
    • Look for the barcode on the left to be sure you have reached the inverter board.
    • As part of the PowerBook 190/5300 Repair Extension Program, the two rightmost screws on some displays were replaced with patch lock screws.
  10. Apple Powerbook 5300 Display Replacement: étape 10, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 10, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 10, image 3 de 3
    • Unscrew the three Torx #8 screws above the white paper backing holding the display to the bezel.
    • Unscrew the three Torx #8 screws below the white paper backing.
    • Remove the tape and peel back the paper backing to access the screws below. Lay back the display EMI insulator and gently lift the inverter board.
    • Use caution; there are four cables attached on three sides of the board.
  11. Apple Powerbook 5300 Display Replacement: étape 11, image 1 de 1
    • Carefully, rotate the inverter board so that it is lying face up near the middle of the display.
    • Disconnect the four cables from the inverter board.
    • Disconnect the four cables carefully. The connectors and cables on the inverter board are fragile, especially the microphone cable.
  12. Apple Powerbook 5300 Display Replacement: étape 12, image 1 de 2 Apple Powerbook 5300 Display Replacement: étape 12, image 2 de 2
    • Remove the two remaining screws holding the display to the display bezel.
    • Disconnect the display cable from the display by gently pulling straight up on the reinforced backing of the cable.
  13. Apple Powerbook 5300 Display Replacement: étape 13, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 13, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 13, image 3 de 3
    • Lift the entire paper and monitor assembly out of its casing. Remove the display from the bezel.
    • Remove the display EMI insulator.
    • Pull up the actual monitor out of its paper shell.
    • Potential for device damage: Be careful not to rip the paper. Watch out for any other wires that might get caught and the speaker cable which is connected to a speaker in the front of the monitor casing.
  14. Apple Powerbook 5300 Display Replacement: étape 14, image 1 de 1
    • Remove the entire display EMI insulator from the casing.
  15. Apple Powerbook 5300 Display Replacement: étape 15, image 1 de 1
    • Replace the new display EMI Insulator.
    • Repeat steps 4-11 to replace the display screen on the purchased replacement monitor.
    • If you want to replace the entire monitor, follow steps 1-3.
  16. Apple Powerbook 5300 Display Replacement: étape 16, image 1 de 3 Apple Powerbook 5300 Display Replacement: étape 16, image 2 de 3 Apple Powerbook 5300 Display Replacement: étape 16, image 3 de 3
    • Replace the screen cover after following steps 7-12 in reverse order.
    • Turn over the display and replace the four bezel screws.
    • Follow steps 1-5 in reverse order to attach the monitor and keyboard back to the unit. Then turn on the laptop to ensure the display is properly working.
    • Overtightening the lower two bezel screws can cause the bezel to crack. As a test, open and close the display assembly once the screws are installed. If the display creaks, loosen the bezel screws.
To reassemble your device, follow steps 1-12 in the instructions in reverse order.
2 autres ont terminé cette réparation.
Scott
Membre depuis le 04/26/11
155 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-30, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 12
30 derniers jours : 26
Total : 3,828
