Aller au contenu principal
Apple Powerbook 5300 Memory Replacement
Ce dont vous avez besoin
  1. Apple Powerbook 5300 Memory Replacement, Battery: étape 1, image 1 de 1
    • Position the Powerbook towards you with the monitor closed.
    • Press the battery removal latch located on the right side of the front panel.
    • Gently slide the battery out.
    • The keyboard, front pane, and hard drive are connected to the laptop's logic board via a ribbon cable. Lift up slowly on each component with one hand and disconnect the ribbons from their ports on the logic board.
  2. Apple Powerbook 5300 Memory Replacement, Keyboard: étape 2, image 1 de 1
    • Turn the laptop over and remove the three T8 torx screws from the bottom panel.
  3. Apple Powerbook 5300 Memory Replacement: étape 3, image 1 de 1
    • Turn the laptop back over and open the monitor.
    • With the monitor facing towards you, gently pull up on the keyboard panel from the bottom.
    • With the keyboard turned over as pictured, carefully remove its ribbon cable from the connection port on the logic board. Use a spudger to lift the white plastic retainer about 1/16" to release the cable.
  4. Apple Powerbook 5300 Memory Replacement, Memory: étape 4, image 1 de 1
    • Pull up on the large green memory chip on the left side of the laptop. It will simply lift out.
Scott
Membre depuis le 04/26/11
155 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 25-30, Garner Spring 2011 Membre de l'équipe Cal Poly, Team 25-30, Garner Spring 2011
CPSU-GARNER-S11S25G30
4 membres
6 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 3
Total : 2,345
