Aller au contenu principal
Introduction
Replacing the front buttons on the display.
  1. Lay the display facing down with the stand away from you. Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
    • Lay the display facing down with the stand away from you.
    • Remove the three size 2.0 hex screws on the swing arm and remove the swing arm as well as the plastic shield under it.
  2. Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
    • Remove the size 2.5 hex screws from each corner that connects the panels to the display and remove them.
  3. Rotate the display so the legs of the display are now facing you
    • Rotate the display so the legs of the display are now facing you
    • Grip the top of the clear panel and lift it upwards, and pull the ADC cable through the hole.
  4. Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
    • Remove the grey back panel by lifting the bottom and pulling the ADC cable through the hole.
  5. The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
    • The next layer will be a shiny metal panel, which might have some stickers. Make sure to remove these stickers.
  6. Fix Kits pour batterie de MacBook
    À partir de $69.99
    Buy Now
    À partir de $69.99
    Buy Now
  7. Now locate and remove the lone screw holding the EMI shield to the display
    • Now locate and remove the lone screw holding the EMI shield to the display
  8. Now that the screw has been removed, slide the panel towards your body and lift it out. You may need to remove the clear USB port cover to remove the metal EMI shield.
    • Now that the screw has been removed, slide the panel towards your body and lift it out.
    • You may need to remove the clear USB port cover to remove the metal EMI shield.
  9. Using the spudger, remove the four black panel covers on the edges of the display.
    • Using the spudger, remove the four black panel covers on the edges of the display.
  10. Remove these screws under the panels.
    • Remove these screws under the panels.
    • There may be more screw holes than actual screws
  11. Remove the two connections that connect the buttons to the logic board
    • Remove the two connections that connect the buttons to the logic board
  12. Remove the outer frame and and pull the cables through the hole. Flip the frame upside down.
    • Remove the outer frame and and pull the cables through the hole. Flip the frame upside down.
  13. The red highlighted box is the power button
    • The red highlighted box is the power button
    • The teal highlighted box is the brightness button
    • This guide will focus on the power button. Removal of the brightness button will follow the same instructions, but you will be working on the left button (teal box) instead of the right (red box)
  14. Remove the screws at the bottom holding the button(s) down
    • Remove the screws at the bottom holding the button(s) down
    • In this picture we are removing the power button
  15. Remove and replace the button(s).
    • Remove and replace the button(s).
Andrew Tsao
Membre depuis le 19/01/2010
159 Réputation
5 tutoriels rédigés
Équipe
Cal Poly, Team 3-20, Maness Winter 2010 Membre de l'équipe Cal Poly, Team 3-20, Maness Winter 2010
CPSU-MANESS-W10S3G20
4 membres
8 tutoriels rédigés
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 3
Total : 2,479
