Introduction
Replace the fan in your Apple TV 1st Generation.
Ce dont vous avez besoin
Starting at one side of the device, use a hairdryer or a heat gun to soften the adhesive holding the rubber base in place.
While the adhesive is still warm, peel the bottom of the rubber base upwards to detach it from the metal plate.
Repeat the procedure described above until the rubber base has been completely removed.
Using a pair of tweezers, squeeze the top of each post and push the post down into the hole. Repeat for all three posts.
4 autres ont terminé cette réparation.
