Introduction
Time and general wear and tear of the Apple TV can cause damage to the bottom cover. This guide will show how to replace the bottom cover on the Apple TV 2nd generation device.
Pièces
Aucune pièce nécessaire.
As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger   to carefully loosen and remove the rubber base/bottom cover from the upper case.
  • As the Apple TV doesn’t have any visible screws or points of entry, the first step is to use a couple of metal spudger to carefully loosen and remove the rubber base/bottom cover from the upper case.
Ajouter un commentaire
Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
  • Position the replacement base over the exposed interior of the Apple TV. Gently press the cover down into the Apple TV until the interior tabs snap into place and the base is attached securely to the upper case.
Areej Bashawiri
Membre depuis le 28/09/2017
201 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team S1-G2, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G2, Diaz Fall 2017
UMAINE-DIAZ-F17S1G2
4 membres
4 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 12
Total : 135
