Introduction
When it comes to electronics, the power supply can eventually fail over time. This guide will show how to replace an old or damaged Apple TV power supply.
As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers  to carefully loosen and remove the rubber base from the upper case.
  • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
  • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
Ajouter un commentaire
  • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
  • Remember, there are also screws hidden underneath the thermal pad.
  • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
  • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
  • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
  • Place the replacement power supply in the now empty spot.
Deanna Rice
Membre depuis le 28/09/2017
252 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team S1-G2, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G2, Diaz Fall 2017
UMAINE-DIAZ-F17S1G2
4 membres
4 tutoriels rédigés
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Réponse
Voir les statistiques:
Dernières 24 heures : 2
7 derniers jours : 9
30 derniers jours : 37
Total : 279
