Aller au contenu principal
Apple TV 2nd Generation Power Supply Replacement
Ce dont vous avez besoin
  1. Apple TV 2nd Generation Power Supply Replacement, Power Supply: étape 1, image 1 de 2 Apple TV 2nd Generation Power Supply Replacement, Power Supply: étape 1, image 2 de 2
    Outil utilisé dans cette étape :
    Metal Spudger
    $2.99
    J'achète
    • As the Apple TV doesn’t have any visible screws or point of entry, the first step is to use a couple of metal spudgers to carefully loosen and remove the rubber base from the upper case.
    • Upon opening the Apple TV, the most noticeable and largest parts will be the heat sink and power supply.
  2. Apple TV 2nd Generation Power Supply Replacement: étape 2, image 1 de 3 Apple TV 2nd Generation Power Supply Replacement: étape 2, image 2 de 3 Apple TV 2nd Generation Power Supply Replacement: étape 2, image 3 de 3
    Phillips #1 Screwdriver
    $5.49
    J'achète
    • Using a #1 Phillips screwdriver, remove the screws holding the heat sink in place.
    • Remember, there are also screws hidden underneath the thermal pad.
    • Next, use a metal spudger to gently pry the logic board up and out of the device. This will allow easier access to the power supply.
  3. Apple TV 2nd Generation Power Supply Replacement: étape 3, image 1 de 2 Apple TV 2nd Generation Power Supply Replacement: étape 3, image 2 de 2
    J'achète
    • The power supply is attached at three different points: the logic board/power supply connector, two screws and a heavy piece of tape, located underneath the power supply.
    • Locate the connector attaching the power supply to the logic board. Using a pair of tweezers, gently remove the connector from the power supply.
    • Using a #1 Phillips screwdriver, remove the two screws located toward the front of the device.
  4. Apple TV 2nd Generation Power Supply Replacement: étape 4, image 1 de 2 Apple TV 2nd Generation Power Supply Replacement: étape 4, image 2 de 2
    • Using a nylon spudger around the edge, gently work the power supply up and out of the case.
    • Place the replacement power supply in the now empty spot.
Deanna Rice
Membre depuis le 09/28/17
261 Réputation
2 tutoriels rédigés
Équipe
University of Maine, Team S1-G2, Diaz Fall 2017 Membre de l'équipe University of Maine, Team S1-G2, Diaz Fall 2017
UMAINE-DIAZ-F17S1G2
4 membres
4 tutoriels rédigés
2 commentaires
There is actually no need to take out the heat sink, just open the bottom, unscrew the power connector, unplug the 8-pin connector from power supply and the power supply is free.
skvarlamatus - Réponse
My power supply of apple tv 2nd gen is damaged, it is not available?
Ceporce - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 4
30 derniers jours : 8
Total : 1,755
