Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Apple TV 4K Logic Board Replacement
Ce dont vous avez besoin
  1. Apple TV 4K Logic Board Replacement, Logic Board: étape 1, image 1 de 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Logic Board Replacement: étape 2, image 1 de 2 Apple TV 4K Logic Board Replacement: étape 2, image 2 de 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Logic Board Replacement: étape 3, image 1 de 2 Apple TV 4K Logic Board Replacement: étape 3, image 2 de 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Logic Board Replacement: étape 4, image 1 de 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Logic Board Replacement: étape 5, image 1 de 3 Apple TV 4K Logic Board Replacement: étape 5, image 2 de 3 Apple TV 4K Logic Board Replacement: étape 5, image 3 de 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
10 autres ont terminé cette réparation.
Keenan Barber
Membre depuis le 10/04/18
1 351 Réputation
3 tutoriels rédigés
Équipe
UW Stout, Team S6-G3, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 membres
15 tutoriels rédigés
9 commentaires de tutoriel
Where does one get a new logic board??
MP94025 - Réponse
Any idea on where I can purchase. new logic board?
tylerchumchal - Réponse
Where do you buy the board…….
Andy Grichtmeier - Réponse
Good job on showing how to remove and replace logic board. Now as the other three commentators have asked
, where can you buy another one or is an exercise in futility
Kanehoe - Réponse
Hm. Has anyone’s Apple TV 4k logic board failed?
oTWR - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 37
30 derniers jours : 193
Total : 10,516
