Aller au contenu principal
Pour réparer ensemble - Je crée un compte
Apple TV 4K Power Connector Replacement
Ce dont vous avez besoin
  1. Apple TV 4K Power Connector Replacement, Logic Board: étape 1, image 1 de 1
    • Use a spudger to pry the bottom panel off from the body. It is held on with clips on the inside, so you will need to make sure those are undone while opening.
    • The panel is held onto the device tightly, so you may need to be a bit forceful to remove it.
  2. Apple TV 4K Power Connector Replacement: étape 2, image 1 de 2 Apple TV 4K Power Connector Replacement: étape 2, image 2 de 2
    • Remove the following screws using a T6 Torx screwdriver holding the heat sink assembly in.
    • Four 10 mm screws
    • Lift and remove the heat sink assembly from the device.
  3. Apple TV 4K Power Connector Replacement: étape 3, image 1 de 2 Apple TV 4K Power Connector Replacement: étape 3, image 2 de 2
    • Use plastic spudger to pull up on all three antenna connectors to remove them.
    • Remove rubber piece from front side of device.
  4. Apple TV 4K Power Connector Replacement: étape 4, image 1 de 1
    • Unscrew the following screws holding the logic board in place using the T7 Torx:
    • Two black 3 mm screws
    • Two silver 4 mm screws
  5. Apple TV 4K Power Connector Replacement: étape 5, image 1 de 3 Apple TV 4K Power Connector Replacement: étape 5, image 2 de 3 Apple TV 4K Power Connector Replacement: étape 5, image 3 de 3
    • Use a spudger to pry up logic board. Try lifting it up from the front side.
    • Remove logic board and set aside.
  6. Apple TV 4K Power Connector Replacement, Power Connector: étape 6, image 1 de 3 Apple TV 4K Power Connector Replacement, Power Connector: étape 6, image 2 de 3 Apple TV 4K Power Connector Replacement, Power Connector: étape 6, image 3 de 3
    • Use a T7 Torx to remove the screws:
    • Five 5mm screws
    • Carefully flip the device upside down to remove the logic board/power supply mount.
  7. Apple TV 4K Power Connector Replacement: étape 7, image 1 de 3 Apple TV 4K Power Connector Replacement: étape 7, image 2 de 3 Apple TV 4K Power Connector Replacement: étape 7, image 3 de 3
    • Disconnect the latch connecting the power connector to the power supply.
    • Feed the wire though the logic board/power supply mount. After this, remove the power connector from the device.
Brian Gehring
Membre depuis le 10/04/18
493 Réputation
2 tutoriels rédigés
Équipe
UW Stout, Team S6-G3, Ogden Fall 2018 Membre de l'équipe UW Stout, Team S6-G3, Ogden Fall 2018
UWSTOUT-OGDEN-F18S6G3
4 membres
15 tutoriels rédigés
0 commentaires de tutoriel
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 4
7 derniers jours : 20
30 derniers jours : 74
Total : 3,997
