Introduction
Use this guide to replace a broken, cracked, or defective display on your Apple Watch Series 6.
This guide shows the procedure on the cellular/LTE version of the watch, but the standard GPS-only version is similar.
You’ll need replacement adhesive to reattach components when reassembling the device.
Before starting repairs, take your watch off the charger and power it down.
If your touchscreen is broken and you can't power off the watch, use this alternate method to power it down.
Because the gap between the screen and watch body is so thin, a sharp blade is needed to separate the two. Read the following warnings carefully before proceeding.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the face of the watch to loosen the display adhesive.
Leave the iOpener on the watch for at least two minutes to fully heat the screen and soften the adhesive holding it to the case.
Place the edge of a curved blade into the thin gap between the display and the outer case. Start at the short side of the display, most distant to the digital crown.
Press firmly straight down into the gap.
Once inserted, tilt the blade to pry the display open slightly.
Prepare an iOpener (or use a hair dryer or heat gun) and heat the rear side of the watch to loosen the battery adhesive. Leave the iOpener on the watch for at least two minutes.
Insert an opening pick between the battery and the Taptic Engine.
Use constant, steady pressure to slowly pry the battery up, separating it from the adhesive securing it to the mainboard.
Carefully lift the battery out of its recess and place it outside the watch case opposite to the Taptic Engine.
Remove the single 1.2 mm-long tri point Y000 screw.
Use a pair of tweezers to carefully peel the black protective tape off both display connectors.
Use the pointed end of a spudger to pry up the lock bars on both ZIF connectors securing the display cables.
To reassemble your Apple Watch Series 6 follow these instructions in reverse order to reattach the screen and the battery.
Apply a little bit of high isopropyl alcohol (>90%) to a Q-tip or use a cleaning pad to gently remove the leftover adhesive on the edges of the watch case and the screen before installing new adhesive.
