Aller au contenu principal
Apple iSight Webcam Privacy Lens Replacement
Ce dont vous avez besoin
  1. Apple iSight Webcam Privacy Lens Replacement, External Body Frame: étape 1, image 1 de 1
    • Remove two 3.55 mm screws that hold the body to the ball and socket joint using the PH000 screwhead.
  2. Apple iSight Webcam Privacy Lens Replacement: étape 2, image 1 de 1
    • Insert the tweezers into the crevice of the ball and socket joint, and prop up the tabs to remove the white ring from the body.
  3. Apple iSight Webcam Privacy Lens Replacement: étape 3, image 1 de 2 Apple iSight Webcam Privacy Lens Replacement: étape 3, image 2 de 2
    • Press the Apple logo through to pull apart the body frame from the body of the webcam.
  4. Apple iSight Webcam Privacy Lens Replacement, Privacy Lens: étape 4, image 1 de 1
    • Remove the end cap with the Apple logo by simply pulling it off.
  5. Apple iSight Webcam Privacy Lens Replacement: étape 5, image 1 de 2 Apple iSight Webcam Privacy Lens Replacement: étape 5, image 2 de 2
    • Unscrew the 3 (3.55 mm) screws surrounding the black casing near the camera-lens.
  6. Apple iSight Webcam Privacy Lens Replacement: étape 6, image 1 de 1
    • Using tweezers, remove the netting that surrounds the black casing.
  7. Apple iSight Webcam Privacy Lens Replacement: étape 7, image 1 de 1
    • Pry open the top of the black casing and pull it off.
    • There is slot on each side just below the power cord connector.
  8. Apple iSight Webcam Privacy Lens Replacement: étape 8, image 1 de 1
    • Unscrew 2 (4.41 mm) screws seen in the picture that surround the attachment of the lens to the main body.
  9. Apple iSight Webcam Privacy Lens Replacement: étape 9, image 1 de 2 Apple iSight Webcam Privacy Lens Replacement: étape 9, image 2 de 2
    • ,Pull the loose circuit strip from its connection using tweezers.
    • Do this for the side connection as well. This enables the entire camera lens section to come off.
    • Pull the camera lens section off the main body.
  10. Apple iSight Webcam Privacy Lens Replacement: étape 10, image 1 de 2 Apple iSight Webcam Privacy Lens Replacement: étape 10, image 2 de 2
    • Unscrew the final (4.41 mm) screw that connects the lens circuitry to the aperture.
    • Then pull off the circuitry top section.
  11. Apple iSight Webcam Privacy Lens Replacement: étape 11, image 1 de 2 Apple iSight Webcam Privacy Lens Replacement: étape 11, image 2 de 2
    • Pull off the top piece of the lens aperture.
    • Finally, remove the privacy lens using tweezers.
4 autres ont terminé cette réparation.
Cullen Shorey
Membre depuis le 03/21/18
271 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S5-G1, Baechle Spring 2018 Membre de l'équipe IUPUI, Team S5-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S5G1
3 membres
3 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 9
Total : 1,161
