Introduction
The first-generation 12" Retina MacBook has a design quirk that requires connection to low-voltage power after a repair. If this step is skipped, permanent logic board damage may result. This procedure is not required for 2016 and later models.
Connecting the Retina MacBook to low-voltage power requires a 5-Watt A/C adapter (like the kind that comes with iPhones) and a USB-A to USB-C cable, neither of which is included in the MacBook's original box.
Using a USB-A to USB-C cable, connect your MacBook to a standard 5 W iPhone wall charger.
  • Using a USB-A to USB-C cable, connect your MacBook to a standard 5 W iPhone wall charger.
Ajouter un commentaire
Plug the charger into a surge-protected A/C outlet.
  • Plug the charger into a surge-protected A/C outlet.
  • Wait until you hear the power connect chime (you should also see the battery charge symbol onscreen).
    • You'll typically hear the chime in 10 seconds or less—unless your battery charge level is very low, in which case it may take up to 15 minutes.
  • Power on your MacBook by pressing the power button.
  • Once the MacBook successfully powers on, you can disconnect the 5 W charger, and use/charge your MacBook normally.
    • If the MacBook fails to power on after 15 minutes, there may be an issue with your repair.
Jeff Suovanen
Membre depuis le 06/08/2013
173 261 Réputation
475 tutoriels rédigés
Équipe
iFixit Membre de l'équipe iFixit
Community
109 membres
6 228 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 10
7 derniers jours : 51
30 derniers jours : 179
Total : 757
