Introduction
Use this guide to replace a malfunctioning rear camera in you bq Aquaris M5.
Pièces
Aucune pièce spécifiée.
Insert the tip of an iFixit opening tool between the back cover and the mid frame of the phone.
Slide the opening tool to the bottom of the phone, to snap out the plastic clips, connecting the back cover and mid frame.
Unscrew the ten black 4mm Phillips #00 Screws from the mainboard shield.
Unscrew the golden 3.4mm Phillips #00 screw on the middle-right side of the mainboard shield.
Use the flat side of a spudger to disconnect the camera's flex cable.
Use Tweezers to grab the camera and lift it out of the phone.
