Aller au contenu principal
Archos Jukebox Recorder 20 Motherboard Replacement
Ce dont vous avez besoin
  1. Archos Jukebox Recorder 20 Motherboard Replacement, Battery: étape 1, image 1 de 1
    • Remove the plastic cover over the batteries on both sides of the device.
  2. Archos Jukebox Recorder 20 Motherboard Replacement: étape 2, image 1 de 1
    • Remove the batteries (may require a plastic opening tool or spudger to pop the batteries out).
  3. Archos Jukebox Recorder 20 Motherboard Replacement, Button Panel: étape 3, image 1 de 1
    • Using the Philips Screwdriver, remove the top 2 screws.
    • The screws are very small (2.5mm), put them somewhere you won't lose them.
  4. Archos Jukebox Recorder 20 Motherboard Replacement: étape 4, image 1 de 1
    • Using the Philips screwdriver, remove the bottom 2 screws (2.5mm).
  5. Archos Jukebox Recorder 20 Motherboard Replacement: étape 5, image 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: étape 5, image 2 de 2
    • Remove the face.
  6. Archos Jukebox Recorder 20 Motherboard Replacement, Motherboard: étape 6, image 1 de 1
    • Remove four surrounding T5 screws as shown
  7. Archos Jukebox Recorder 20 Motherboard Replacement: étape 7, image 1 de 1
    • Remove all four purple bumpers. You may have to bend the metal surround out of the way.
  8. Archos Jukebox Recorder 20 Motherboard Replacement: étape 8, image 1 de 1
    • Remove metal surround from the Jukebox. You may have to straighten out tabs that were bent during disassembly.
  9. Archos Jukebox Recorder 20 Motherboard Replacement: étape 9, image 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: étape 9, image 2 de 2
    Outil utilisé dans cette étape :
    Desoldering Pump
    $3.99
    J'achète
    • Desolder the motherboard from the frame at the eight locations shown. You may need to use a desoldering pump.
  10. Archos Jukebox Recorder 20 Motherboard Replacement: étape 10, image 1 de 2 Archos Jukebox Recorder 20 Motherboard Replacement: étape 10, image 2 de 2
    • Desolder the remaining two points on the backside of the Jukebox.
    • The Motherboard should now be free from the frame and ready for repair or replacement.
Shaun Rifield
Membre depuis le 03/21/18
121 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team S2-G3, Freund Spring 2018 Membre de l'équipe IUPUI, Team S2-G3, Freund Spring 2018
IUPUI-FREUND-S18S2G3
3 membres
2 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 8
30 derniers jours : 11
Total : 397
