Aller au contenu principal
  1. Get the watch ready by placing it on its face.
    • Get the watch ready by placing it on its face.
  2. Pick a location that is by the band so that if you make any scratches they will be less obvious when you are done. Place the screwdriver between the frame and the back cover. Gently tap the back of the screwdriver with a small hammer or whatever you have around. Do not use your hand!
    • Pick a location that is by the band so that if you make any scratches they will be less obvious when you are done. Place the screwdriver between the frame and the back cover. Gently tap the back of the screwdriver with a small hammer or whatever you have around. Do not use your hand!
  3. Fix Kits pour batteries d'iPhone
    Seulement $29.99
    Buy Now
    Seulement $29.99
    Buy Now
  4. Remove back.
    • Remove back.
  5. While securing the inside of the watch with a finger or thumb, gently pry out the battery.
    • While securing the inside of the watch with a finger or thumb, gently pry out the battery.
  6. Insert a new battery. Line up the cover in the correct position.  Keep the notch lined up with the winding screw. Secure the back to the frame by applying equal pressure and squeezing the two parts together.
    • Insert a new battery. Line up the cover in the correct position. Keep the notch lined up with the winding screw. Secure the back to the frame by applying equal pressure and squeezing the two parts together.
Matthew Radice
Membre depuis le 18/01/2016
122 Réputation
1 tutoriel rédigé
Ajouter un commentaire
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 1
Total : 32
