Introduction
The device will be disassembled down to the motor, the power cords will be disconnected, and the motor removed of your ArmorAll AA255.
Ce dont vous avez besoin
Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
Use a PH2 screwdriver to remove the five 15mm screws on the ball cage under the main housing.
Pull the ball cage to remove it from the main housing.
6 autres ont terminé cette réparation.
4 commentaires
Medida de los carboncitos que lleva el motor?
Buenas nochew necesito saber si existe a la venta la hélice o ventiladora que hace la succión de la aspiradora. Porfavor alguien puede ayudarme dejo mi correo erikazavala2882@gmail.com desde Honduras.
Part #for motor ???? Mine just the carbon brush is worn. Need replacement part # for motor or brushes ????
