Aller au contenu principal
ArmorAll AA255 Power Cord Replacement
Ce dont vous avez besoin
  1. ArmorAll AA255 Power Cord Replacement, Lower Motor Housing: étape 1, image 1 de 1
    • Remove the orange main housing unit from the vacuum bucket by pulling outward on the handle tabs while lifting upward as shown.
  2. ArmorAll AA255 Power Cord Replacement: étape 2, image 1 de 1
    • Remove the five 15mm PH2 screws.
  3. ArmorAll AA255 Power Cord Replacement: étape 3, image 1 de 1
    • Remove the 15 mm T20 screw. This screw is located nearest the power cord.
  4. ArmorAll AA255 Power Cord Replacement: étape 4, image 1 de 2 ArmorAll AA255 Power Cord Replacement: étape 4, image 2 de 2
    • Gently separate the upper and lower sections of the main housing.
  5. ArmorAll AA255 Power Cord Replacement, Power Cord: étape 5, image 1 de 1
    • Pull the black wire from the power cord out of the switch.
    • There are no clips or tabs that hold this wire in place. Just pull strongly to remove it.
    • Don't remove both black wires. Only the black wire that comes from the power cord itself needs to be removed. The one going to the motor can be left alone.
  6. ArmorAll AA255 Power Cord Replacement: étape 6, image 1 de 1
    • Remove the five 15mm screws from the plastic motor cover and power cord clamp using a PH2 screwdriver.
  7. ArmorAll AA255 Power Cord Replacement: étape 7, image 1 de 2 ArmorAll AA255 Power Cord Replacement: étape 7, image 2 de 2
    • Remove the plastic motor cover.
    • Be sure to loosen the white wire from the notch in the plastic motor cover by pulling it upwards.
  8. ArmorAll AA255 Power Cord Replacement: étape 8, image 1 de 2 ArmorAll AA255 Power Cord Replacement: étape 8, image 2 de 2
    • Detach the white wire from the motor by pulling upwards on the wire as you depress the small metal tab on the connector with a nylon spudger.
    • When working with electronics, it's important to choose a tool that's ESD-safe to avoid accidental damage to the device. The regular black nylon spudger or a plastic opening tool should be used whenever possible.
3 autres ont terminé cette réparation.
Abel Manring
Membre depuis le 02/10/16
263 Réputation
1 tutoriel rédigé
Équipe
IUPUI, Team 2-1, Baechle Spring 2016 Membre de l'équipe IUPUI, Team 2-1, Baechle Spring 2016
IUPUI-BAECHLE-S16S2G1
4 membres
4 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 23
Total : 1,013
