Aller au contenu principal
Aroma ARC-914SBD Lid Replacement
Ce dont vous avez besoin
  1. Aroma ARC-914SBD Lid Replacement, Lid: étape 1, image 1 de 2 Aroma ARC-914SBD Lid Replacement, Lid: étape 1, image 2 de 2
    • The first step is removing the condensation catcher in order to reach the control panel. We do this by pinching the condensation catcher as shown, on both sides and pull the condensation catcher away from the cooker.
  2. Aroma ARC-914SBD Lid Replacement: étape 2, image 1 de 1
    • Once the condensation catcher has been removed, set it aside for reassembly later.
    • Now make sure you have a a Phillips head screwdriver, size PH2. This tool will allow you to remove the screw that was behind the condensation catcher.
  3. Aroma ARC-914SBD Lid Replacement: étape 3, image 1 de 2 Aroma ARC-914SBD Lid Replacement: étape 3, image 2 de 2
    • Gently remove the piece that was held in place by the screw, you do this by pulling out from the top, then pulling up. This will expose the hinges for the lid.
  4. Aroma ARC-914SBD Lid Replacement: étape 4, image 1 de 3 Aroma ARC-914SBD Lid Replacement: étape 4, image 2 de 3 Aroma ARC-914SBD Lid Replacement: étape 4, image 3 de 3
    • To remove the hinge, gently rotate the bottom of the rod upwards, then push inward to pull the rod out. Repeat the process for each rod. This will allow the lid to be removed.
Brandon Nieves
Membre depuis le 09/04/15
956 Réputation
8 tutoriels rédigés
Équipe
USF Tampa, Team 2-3, Sullivan Fall 2015 Membre de l'équipe USF Tampa, Team 2-3, Sullivan Fall 2015
USFT-SULLIVAN-F15S2G3
3 membres
8 tutoriels rédigés
Un commentaire
Where can you buy a replacement lid?
Cristian Ortiz - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 9
30 derniers jours : 31
Total : 2,255
