Aller au contenu principal
Astro A40 TR Motherboard Replacement
Ce dont vous avez besoin
  1. Astro A40 TR Motherboard Replacement, Speakers: étape 1, image 1 de 2 Astro A40 TR Motherboard Replacement, Speakers: étape 1, image 2 de 2
    • To access the speakers you need to disassemble the earpiece. First remove the foam ear piece by simply pinching the padding and pulling lightly until the magnets disengage.
  2. Astro A40 TR Motherboard Replacement: étape 2, image 1 de 3 Astro A40 TR Motherboard Replacement: étape 2, image 2 de 3 Astro A40 TR Motherboard Replacement: étape 2, image 3 de 3
    • Remove the dust cover located on the speaker. Use the corner of the spudger to peel underneath the cover until you can lift it by hand. The cover is held onto the device with adhesive and should be removed slowly.
  3. Astro A40 TR Motherboard Replacement: étape 3, image 1 de 2 Astro A40 TR Motherboard Replacement: étape 3, image 2 de 2
    • Take off the front cover by removing the four screws located in a square formation on the surface of the device. Use the J00 Philips driver listed in the device page.
  4. Astro A40 TR Motherboard Replacement: étape 4, image 1 de 2 Astro A40 TR Motherboard Replacement: étape 4, image 2 de 2
    • Locate the three small screws under the speaker. Use the J00 Philips Driver to remove them.
  5. Astro A40 TR Motherboard Replacement: étape 5, image 1 de 1
    • If your issue is asking for the complete replacement of the speaker or the motherboard, un-solder the old components and replace with new speaker by re-soldering.
    • Check out this useful guide on how to solder and desolder connections if soldering is new to you.
  6. Astro A40 TR Motherboard Replacement, Microphone Jack: étape 6, image 1 de 1
    • Remove the three screws in the photo with the J00 driver bit, and pull the headphone jack away from the assembly.
  7. Astro A40 TR Motherboard Replacement: étape 7, image 1 de 1
    • Un-solder the two wires circled, at this point the entire assembly can be removed from the speaker and the remainder of the device.
  8. Astro A40 TR Motherboard Replacement, Motherboard: étape 8, image 1 de 2 Astro A40 TR Motherboard Replacement, Motherboard: étape 8, image 2 de 2
    • Pull the motherboard off of the jack and replace it with a new one by re-soldering the wires.
Mike
Membre depuis le 10/20/16
448 Réputation
3 tutoriels rédigés
Équipe
UMass Dartmouth, Team 6-5, Martin Fall 2016 Membre de l'équipe UMass Dartmouth, Team 6-5, Martin Fall 2016
UMASSD-MARTIN-F16S6G5
3 membres
10 tutoriels rédigés
Un commentaire
Hi I hope you can answer ASAP
Why did you replace that?
I’m asking this cuz i got a problem with mines, i insert the mic and didn’t work, its like a false
Gabriel Cruz V - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 6
30 derniers jours : 26
Total : 2,440
