Aller au contenu principal
Astro A40 TR Plus Mixamp M80 Headband Replacement
Ce dont vous avez besoin
  1. Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: étape 1, image 1 de 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: étape 1, image 2 de 3 Astro A40 TR Plus Mixamp M80 Headband Replacement, Headband Adjusters: étape 1, image 3 de 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the upper headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the upper headband plate.
    • Remove the upper headband plate.
    • Repeat the past three steps for the upper headband plate on the other side.
  2. Astro A40 TR Plus Mixamp M80 Headband Replacement: étape 2, image 1 de 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: étape 2, image 2 de 3 Astro A40 TR Plus Mixamp M80 Headband Replacement: étape 2, image 3 de 3
    • Use a screwdriver with a H2.0 head to remove the two screws on the lower headband plate.
    • Use a screwdriver with a T9 bit to remove one screw from the lower headband plate.
    • Remove the lower headband plate.
    • Repeat the past three steps for the lower headband plate on the other side.
  3. Astro A40 TR Plus Mixamp M80 Headband Replacement: étape 3, image 1 de 1
    • Use your hand to remove the headband adjuster.
Yang Li
Membre depuis le 06/28/17
541 Réputation
5 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 4
30 derniers jours : 27
Total : 2,899
