Aller au contenu principal
Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement
Ce dont vous avez besoin
  1. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Ear Cushions: étape 1, image 1 de 2 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Ear Cushions: étape 1, image 2 de 2
    • Use your hand to firmly grasp the cushion and remove it from the speaker.
    • Repeat the process for the other side if needed.
    • The best place to grip it is where there is a tab sticking out. The tab will make it easier to remove.
    • When reassembling, note the curvature of the cushion to determine whether it's the left or the right cushion.
  2. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: étape 2, image 1 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: étape 2, image 2 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Motherboard: étape 2, image 3 de 3
    • Slide the plastic spudger beneath the dust cover of the speaker.
    • Lift the dust cover up with the plastic spudger.
    • Using your fingers, completely remove the dust cover from the speaker.
  3. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 3, image 1 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 3, image 2 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 3, image 3 de 3
    • Remove four 5 mm screws from the speaker protector using a JIS #1 screwdriver.
    • Use your hands to remove the speaker protector.
  4. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 4, image 1 de 2 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 4, image 2 de 2
    • Remove the two 2 mm long screws securing the motherboard using a Phillips #000 screwdriver.
  5. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 5, image 1 de 2 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement: étape 5, image 2 de 2
    • Use your fingers to hold the wire located by the covered part and gently lift it out of its cradle.
    • Carefully use your fingers to disconnect the colored wires connected to the motherboard.
    • If replacing the wires, ensure you carefully disconnect the remaining colored wires to replace them with new standard wires.
  6. Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: étape 6, image 1 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: étape 6, image 2 de 3 Astro A40 TR Plus Mixamp M80 Wires in speaker Replacement, Wires in speaker: étape 6, image 3 de 3
    • Use your fingers to remove the black wire from your headphones.
Yang Li
Membre depuis le 06/28/17
541 Réputation
5 tutoriels rédigés
Un commentaire
But where do I buy the replacement speaker
David Landeros - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 8
30 derniers jours : 24
Total : 1,634
