Introduction
Use when the USB port needs to be removed. (Soldering Required)
Ce dont vous avez besoin
Grip the dial tightly and pull straight off the device.
Repeat for the second dial
Insert a plastic opening tool into the seam between the rubber foot and plastic casing.
Pull the rubber foot free of the plastic casing.
Press the tip of a hot soldering iron to the USB connection to melt the solder.
Use a nylon spudger to lift the USB from the solder.
Repeat for each of the four USB connections.
2 autres ont terminé cette réparation.
4 commentaires
What port is used as a replacement?
Did you ever identify an appropriate replacement port?
Lepec -
something was broken out of the port of the USB connection
Will this method work with the 2015 tr mixamp?
