Aller au contenu principal
Asus 1015E-DS03 Keyboard Replacement
Ce dont vous avez besoin
  1. Asus 1015E-DS03 Keyboard Replacement, Battery: étape 1, image 1 de 1
    • Hold the laptop using both hands with the battery facing upwards.
  2. Asus 1015E-DS03 Keyboard Replacement: étape 2, image 1 de 1
    • Push the two tabs located below the battery in towards each other using your thumbs.
  3. Asus 1015E-DS03 Keyboard Replacement: étape 3, image 1 de 1
    • Push the battery upwards and out of the laptop as shown.
  4. Asus 1015E-DS03 Keyboard Replacement: étape 4, image 1 de 1
    • Continue to push the battery upwards until it is completely separated from the laptop as shown.
  5. Asus 1015E-DS03 Keyboard Replacement, Keyboard: étape 5, image 1 de 1
    • Once the battery is removed, unscrew the highlighted 3mm screws (4) using a #0 Phillps head screwdriver.
    • Be very careful not to lose the screws, these four screws are very small.
  6. Asus 1015E-DS03 Keyboard Replacement: étape 6, image 1 de 2 Asus 1015E-DS03 Keyboard Replacement: étape 6, image 2 de 2
    • After all four screws are removed, flip the laptop over with the keyboard facing up.
    • Use a spudger to pry up where the keyboard is attached to the laptop on all sides until it is detached from the laptop.
    • It is normal to hear cracking noises when prying off the keyboard.
    • After keyboard is detached from laptop, there is a ribbon cable still attached to the motherboard. See next step before completely removing keyboard.
  7. Asus 1015E-DS03 Keyboard Replacement: étape 7, image 1 de 1
    • After the keyboard is detached, the ribbon cable which connects the keyboard to the laptop's motherboard is exposed.
    • Be careful not to tear or rip the ribbon cable.
  8. Asus 1015E-DS03 Keyboard Replacement: étape 8, image 1 de 1
    • Using the spudger push the white clips upwards that are holding the cable.
  9. Asus 1015E-DS03 Keyboard Replacement: étape 9, image 1 de 2 Asus 1015E-DS03 Keyboard Replacement: étape 9, image 2 de 2
    • Gently pull the strip out of the square slot.
2 autres ont terminé cette réparation.
Joe Capriola
Membre depuis le 03/21/16
428 Réputation
3 tutoriels rédigés
Équipe
Clemson, Team 7-4, Benson Spring 2016 Membre de l'équipe Clemson, Team 7-4, Benson Spring 2016
CLEM-BENSON-S16S7G4
5 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 3
30 derniers jours : 13
Total : 978
