Aller au contenu principal
Asus A52F Hard Drive Replacement
Ce dont vous avez besoin
  1. Asus A52F Hard Drive Replacement, Battery: étape 1, image 1 de 2 Asus A52F Hard Drive Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Hard Drive Replacement: étape 2, image 1 de 2 Asus A52F Hard Drive Replacement: étape 2, image 2 de 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Hard Drive Replacement, Lower Case: étape 3, image 1 de 3 Asus A52F Hard Drive Replacement, Lower Case: étape 3, image 2 de 3 Asus A52F Hard Drive Replacement, Lower Case: étape 3, image 3 de 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Hard Drive Replacement: étape 4, image 1 de 2 Asus A52F Hard Drive Replacement: étape 4, image 2 de 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Hard Drive Replacement, Hard Drive: étape 5, image 1 de 3 Asus A52F Hard Drive Replacement, Hard Drive: étape 5, image 2 de 3 Asus A52F Hard Drive Replacement, Hard Drive: étape 5, image 3 de 3
    • Remove the four Phillips #0 screws holding the hard drive case to the laptop.
    • Lift the hard drive upwards by the two arms in order to remove the hard drive case from the laptop.
  6. Asus A52F Hard Drive Replacement: étape 6, image 1 de 2 Asus A52F Hard Drive Replacement: étape 6, image 2 de 2
    • Using a Phillips #0 screwdriver, remove the cage screws on the side of the hard drive.
  7. Asus A52F Hard Drive Replacement: étape 7, image 1 de 2 Asus A52F Hard Drive Replacement: étape 7, image 2 de 2
    • Next, slide the case off of the broken hard drive.
    • Slide the working hard drive into the case and screw it on.
Roman Justice
Membre depuis le 03/08/17
225 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 18
Total : 1,528
