Aller au contenu principal
Asus A52F Wifi Card Replacement
Ce dont vous avez besoin
  1. Asus A52F Wifi Card Replacement, Battery: étape 1, image 1 de 2 Asus A52F Wifi Card Replacement, Battery: étape 1, image 2 de 2
    • Place the laptop face down with the battery facing away from you.
    • Locate the two buttons next to the battery.
    • Slide the right slider to the unlocked (red) position.
  2. Asus A52F Wifi Card Replacement: étape 2, image 1 de 2 Asus A52F Wifi Card Replacement: étape 2, image 2 de 2
    • Hold the left button to the left.
    • Slide the battery with your other hand away from you and it should disconnect.
  3. Asus A52F Wifi Card Replacement, Lower Case: étape 3, image 1 de 3 Asus A52F Wifi Card Replacement, Lower Case: étape 3, image 2 de 3 Asus A52F Wifi Card Replacement, Lower Case: étape 3, image 3 de 3
    • Remove the five Phillips # 0 screws from the back panel.
    • Using your finger or a plastic spudger start to carefully pry up the back planel.
  4. Asus A52F Wifi Card Replacement: étape 4, image 1 de 2 Asus A52F Wifi Card Replacement: étape 4, image 2 de 2
    • Slide the back panel away and remove the panel.
  5. Asus A52F Wifi Card Replacement, Wifi Card: étape 5, image 1 de 2 Asus A52F Wifi Card Replacement, Wifi Card: étape 5, image 2 de 2
    • First, find the Wi-Fi card
    • Move the protective flap back and use a Phillips size 0 screw driver to remove the two screws.
  6. Asus A52F Wifi Card Replacement: étape 6, image 1 de 3 Asus A52F Wifi Card Replacement: étape 6, image 2 de 3 Asus A52F Wifi Card Replacement: étape 6, image 3 de 3
    • First remove both of the wires from the WiFi card.
    • Lift the WiFi card up and remove it.
Roman Justice
Membre depuis le 03/08/17
225 Réputation
2 tutoriels rédigés
Équipe
UMass Dartmouth, Team S5-G1, Botvin Spring 2017 Membre de l'équipe UMass Dartmouth, Team S5-G1, Botvin Spring 2017
UMASSD-BOTVIN-S17S5G1
4 membres
7 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 5
30 derniers jours : 17
Total : 1,796
