Introduction
A broken or malfunctioning keyboard can render your computer unusable. Luckily, replacing the keyboard of the A53U-ES21 is rather simple and can save you the expense of having to replace the entire computer.
Ce dont vous avez besoin
Remove the RAM cover from the bottom of the keyboard.
Remove the 5mm screw keeping the panel in place using a Phillips #1 screwdriver.
Work the pry tool along the edge to finish removal.
Unscrew the two 7mm screws marked with an engraved "K" using a #1 Phillips screwdriver.
Orient the computer so the keyboard is facing toward you with the screen at the top.
Find the three buttons to depress at top of the keyboard, set in the crack between the casing and the keyboard, highlighted here in red.
Use the pry tool to depress the buttons. The keyboard should pop out.
