Aller au contenu principal
Réparez vos affaires
Droit à la réparation
Pièces & Outils
Introduction
The wireless card is how your laptop communicates with Wi-Fi networks. Newer protocols are developed and introduced over the years that can improve wireless speed and security, but only if the wireless card is capable of understanding them. Upgrading your Asus A53U-ES21's wireless card can increase the speed of downloading, streaming, and general communication of the Internet.
Pièces
Aucune pièce spécifiée.
  1. Make sure the laptop is off. Flip the laptop upside down so that the battery is facing you.
    • Make sure the laptop is off.
    • Flip the laptop upside down so that the battery is facing you.
  2. Move the two sliders towards the outer edge of the laptop. Pull the battery out with your left hand while holding the right slider.
    • Move the two sliders towards the outer edge of the laptop.
    • Pull the battery out with your left hand while holding the right slider.
  3. Kits pour Nintendo Switch
    Une solution rapide pour reprendre le jeu
    Acheter un kit pour Switch
  4. Remove the 5mm screw using a Phillips #1 screwdriver. Use the iFixit opening tools to remove the panel. Use the iFixit opening tools to remove the panel.
    • Remove the 5mm screw using a Phillips #1 screwdriver.
    • Use the iFixit opening tools to remove the panel.
  5. Detach the two cables connected to the wireless card (the opening tool works well for this). Remove the 4mm screw (highlighted in orange). Pull the wireless card up and remove it from the device.
    • Detach the two cables connected to the wireless card (the opening tool works well for this).
    • Remove the 4mm screw (highlighted in orange).
    • Pull the wireless card up and remove it from the device.
Chase Poirier
Membre depuis le 23/10/2018
505 Réputation
5 tutoriels rédigés
Équipe
UMass Dartmouth, Team S1-G3, Simcock Fall 2018 Membre de l'équipe UMass Dartmouth, Team S1-G3, Simcock Fall 2018
UMASSD-SIMCOCK-F18S1G3
3 membres
7 tutoriels rédigés
Ajouter un commentaire
Afficher les statistiques:
Dernières 24 heures : 0
7 derniers jours : 1
30 derniers jours : 6
Total : 90
