Introduction
Is your battery damaged or keep dying? Then this is the guide for you.
Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
  • Use a metal spudger to pry off the two feet closest to the hinge of the laptop.
  • The feet are attached to the laptop by adhesives, therefore they may not stick as well after multiple removals.
Ajouter un commentaire
Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
  • Use a Phillips #0 screwdriver to unscrew the six 5mm screws.
  • Use a Phillips #0 screwdriver to unscrew the two 6mm screws.
  • Use a plastic opening tool to pry the keyboard off the edges of the computer.
  • The edges will make a popping noise.
  • Flip up the white bar that connects the thin white strip using a plastic opening tool.
  • Grab the thin white strip and pull straight back to remove the strip from the connector.
  • Use a plastic opening tool to lift the black bar above the wide black strip in the connector.
  • Grab the wide black strip and pull straight back to remove the strip from the connector.
  • Remove the keyboard by lifting it straight up.
  • Unscrew the seven 4mm screws using a Phillips #0 screwdriver.
  • Wiggle the plate back and forth to loosen the adhesive under the plate.
  • The adhesive will not be the same after removal and more adhesive may be necessary upon reassembly.
  • Rotate the screwdriver in a counterclockwise direction to remove the screws.
  • Do not rest your arm or hand in the adhesive.
  • Use a Phillips #0 screwdriver to unscrew the 4mm screws. Rotate the screwdriver in a counterclockwise direction to undo the screws.
  • Remove the rainbow connector by firmly grasping the rainbow wires and pulling straight back. It will help to brace the motherboard when you pull.
  • Use the plastic opening tool to lift up the battery and remove it.
  • Do not dispose of the battery in normal waste. The chemicals inside are toxic. Find out where to dispose of properly in your neighborhood.
Ashley Humpal
Membre depuis le 18/04/2018
185 Réputation
1 tutoriel rédigé
Équipe
Cal Poly, Team S17-G4, Livingston Spring 2018 Membre de l'équipe Cal Poly, Team S17-G4, Livingston Spring 2018
CPSU-LIVINGSTON-S18S17G4
4 membres
6 tutoriels rédigés
Voir les statistiques:
Dernières 24 heures : 0
7 derniers jours : 0
30 derniers jours : 4
Total : 72
