Aller au contenu principal
Asus Chromebook C202 Input/Output board Replacement
Ce dont vous avez besoin
    • Remove ten 8 mm Phillips #1 screws from the bottom of the Chromebook using a Phillips #1 screwdriver.
    • Two of the screws are hidden by rubber caps along the rubber rest of the device. Use tweezers to get them out.
    • Place the plastic opening tool into the edges between the front of the Chromebook and the back of it with the upper scoop of the opening tool facing upward.
    • Push down on the plastic opening tool to unhinge the top portion of the Chromebook from its lower portion. Opening the Chromebook all the way where the display touches the ground helps in opening up the top edge.
    • Use your hand to gently lift the top portion of the Chromebook from the bottom portion of it to avoid damaging the ribbon cables.
  1. Asus Chromebook C202 Input/Output board Replacement: étape 3, image 1 de 1
    • Gently disconnect the ribbon cable connecting the trackpad to the motherboard.
    • Gently disconnect the ribbon cable connecting the keyboard to the motherboard.
  2. Asus Chromebook C202 Input/Output board Replacement, Battery: étape 4, image 1 de 3 Asus Chromebook C202 Input/Output board Replacement, Battery: étape 4, image 2 de 3 Asus Chromebook C202 Input/Output board Replacement, Battery: étape 4, image 3 de 3
    • Pull the latch out on both the Input/Output board as well as the motherboard.
    • Gently remove the ribbon cable connecting the I/O board to the motherboard.
  3. Asus Chromebook C202 Input/Output board Replacement: étape 5, image 1 de 3 Asus Chromebook C202 Input/Output board Replacement: étape 5, image 2 de 3 Asus Chromebook C202 Input/Output board Replacement: étape 5, image 3 de 3
    • Remove two 4 mm Phillips #1 screws from the metal grate connected to the battery.
    • Remove metal grate from battery.
    • Remove six 4 mm Phillips #1 screws from the battery
  4. Asus Chromebook C202 Input/Output board Replacement: étape 6, image 1 de 2 Asus Chromebook C202 Input/Output board Replacement: étape 6, image 2 de 2
    • Disconnect the battery from the motherboard.
    • Lift battery from the bottom portion of the Chromebook.
  5. Asus Chromebook C202 Input/Output board Replacement: étape 7, image 1 de 1
    • Remove the battery from the Chromebook.
  6. Asus Chromebook C202 Input/Output board Replacement, Input/Output board: étape 8, image 1 de 2 Asus Chromebook C202 Input/Output board Replacement, Input/Output board: étape 8, image 2 de 2
    • Remove 2 4 mm Phillips #1 screws connecting the I/O board to the Chromebook.
    • Lift the I/O board from the Chromebook.
2 autres ont terminé cette réparation.
Christopher Segale
Membre depuis le 09/28/16
859 Réputation
6 tutoriels rédigés
Équipe
USF Tampa, Team 3-1, Passmore Fall 2016 Membre de l'équipe USF Tampa, Team 3-1, Passmore Fall 2016
USFT-PASSMORE-F16S3G1
4 membres
11 tutoriels rédigés
Un commentaire
Thanks for all your ASUS guides — saved me a packet when my son breaks his!
Nick Huggett - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 0
7 derniers jours : 2
30 derniers jours : 10
Total : 905
