Aller au contenu principal
Asus Chromebook C202SA-YS02 Touch Pad Replacement
Ce dont vous avez besoin
  1. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Palm Rest: étape 1, image 1 de 1
    • Turn the device over so the bottom is facing up.
    • Remove the ten Phillips #1 8.0 mm screws.
  2. Asus Chromebook C202SA-YS02 Touch Pad Replacement: étape 2, image 1 de 2 Asus Chromebook C202SA-YS02 Touch Pad Replacement: étape 2, image 2 de 2
    • Carefully use the plastic opening tool to pry the palm rest apart from the bottom cover. Start from one spot and systematically work your way around until the whole palm rest is detached.
  3. Asus Chromebook C202SA-YS02 Touch Pad Replacement: étape 3, image 1 de 1
    • Disconnect the two cables that run from the keyboard to the motherboard and from the touch pad to the motherboard.
    • You may have to use a spudger to lift open the respective latches.
  4. Asus Chromebook C202SA-YS02 Touch Pad Replacement, Touch Pad: étape 4, image 1 de 1
    • Gently peel off gold tape.
  5. Asus Chromebook C202SA-YS02 Touch Pad Replacement: étape 5, image 1 de 1
    • Remove the three Phillips #1 3.5 mm screws located on the under-side of the palm rest.
    • You can now pop out the touch pad.
Beau Hansen
Membre depuis le 09/28/17
836 Réputation
7 tutoriels rédigés
Équipe
Idaho State University, Team S4-G4, Watkins Fall 2017 Membre de l'équipe Idaho State University, Team S4-G4, Watkins Fall 2017
ISU-WATKINS-F17S4G4
4 membres
13 tutoriels rédigés
0 commentaires
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 1
7 derniers jours : 2
30 derniers jours : 9
Total : 1,085
