Introduction
This Asus Chromebook C213SA-YS02 guide is for when troubleshooting has failed and the keyboard remains nonfunctional. This could be due to things such as broken keys and/or broken signal connections that can not be fixed. A purchase of the compatible keyboards and a few minutes of installation can get the laptop running again.
Ce dont vous avez besoin
Power off the device by pressing and holding the power button on the side of the device.
Remove the power cable from the back of the device (if applicable).
Remove the seven black 4mm Phillips screws underneath the back cover.
Remove the eight black 7mm Phillips #00 screws along the edge of the device.
Remove the single silver 2mm Phillips #00 screw from the top of the Wi-Fi card.
Carefully pull the white and black wires out of the card using tweezers.
Remove the Wi-Fi card.
Disconnect the black camera cable between the keyboard cable and the two blue ribbons which have been disconnected.
Using the tweezers, grab the wire end of the cable and carefully pull it away from the connection port.
Loosely place the disconnected cable away from the connection port.
Flip the device over and open up the LCD screen.
Using the iFixit opening tool, gently place the tool in between the back-plate and the keyboard and lift up.
Slide the tool around the outside of the keyboard and lift up the tool while moving it around the boundary of the keyboard.
Pull the keyboard away from the back-plate. Be careful the keyboard cable is not caught on the back-plate while performing this maneuver.
