Aller au contenu principal
Asus Chromebook C523N Keyboard Replacement
Ce dont vous avez besoin
  1. Asus Chromebook C523N Keyboard Replacement, Back Cover: étape 1, image 1 de 2 Asus Chromebook C523N Keyboard Replacement, Back Cover: étape 1, image 2 de 2
    • Remove the four 0.5mm JIS #00 screws from the bottom edge of the Chromebook and one in the center.
    • Remove the six 1.7mm JIS #00 screws from the sides and top edge of the Chromebook.
  2. Asus Chromebook C523N Keyboard Replacement: étape 2, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 2, image 2 de 2
    • Using a spudger, lift the top left base pad and remove it to reveal a final screw underneath.
    • Remove the one 0.5mm JIS #00 screw underneath the base pad.
  3. Asus Chromebook C523N Keyboard Replacement: étape 3, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 3, image 2 de 2
    • Use an opening tool to gently pry the base enclosure up and remove from the laptop.
  4. Asus Chromebook C523N Keyboard Replacement, Speaker: étape 4, image 1 de 3 Asus Chromebook C523N Keyboard Replacement, Speaker: étape 4, image 2 de 3 Asus Chromebook C523N Keyboard Replacement, Speaker: étape 4, image 3 de 3
    Outil utilisé dans cette étape :
    • Using the nylon tipped tweezers, gently pry the black and white wires from the wireless card and lift.
  5. Asus Chromebook C523N Keyboard Replacement: étape 5, image 1 de 3 Asus Chromebook C523N Keyboard Replacement: étape 5, image 2 de 3 Asus Chromebook C523N Keyboard Replacement: étape 5, image 3 de 3
    • Use a spudger to pry the small tangle of black, red, white, and blue wires from the audio connector, pushing the wires back toward the speaker.
  6. Asus Chromebook C523N Keyboard Replacement: étape 6, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 6, image 2 de 2
    • Use a spudger to pry the black wire from the audio connector, pushing the wires back toward the left speaker.
  7. Asus Chromebook C523N Keyboard Replacement: étape 7, image 1 de 1
    • Gently grab both speakers and lift them from the Chromebook to remove.
  8. Asus Chromebook C523N Keyboard Replacement, Battery: étape 8, image 1 de 3 Asus Chromebook C523N Keyboard Replacement, Battery: étape 8, image 2 de 3 Asus Chromebook C523N Keyboard Replacement, Battery: étape 8, image 3 de 3
    • To disconnect the cable, use the tip of a spudger or your fingernail to flip up the small locking flap.
    • Gently disconnect the battery cable from the motherboard.
  9. Asus Chromebook C523N Keyboard Replacement: étape 9, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 9, image 2 de 2
    • Remove six 1.4 mm JIS #00 screws from the battery.
  10. Asus Chromebook C523N Keyboard Replacement: étape 10, image 1 de 1
    • Remove the battery from the laptop.
  11. Asus Chromebook C523N Keyboard Replacement, Motherboard: étape 11, image 1 de 3 Asus Chromebook C523N Keyboard Replacement, Motherboard: étape 11, image 2 de 3 Asus Chromebook C523N Keyboard Replacement, Motherboard: étape 11, image 3 de 3
    • Using tweezers, gently pry the black and white wires from the wireless card and lift.
  12. Asus Chromebook C523N Keyboard Replacement: étape 12, image 1 de 3 Asus Chromebook C523N Keyboard Replacement: étape 12, image 2 de 3 Asus Chromebook C523N Keyboard Replacement: étape 12, image 3 de 3
    • Gently pull the trackpad cable from the connector, located next to the wireless card.
  13. Asus Chromebook C523N Keyboard Replacement: étape 13, image 1 de 3 Asus Chromebook C523N Keyboard Replacement: étape 13, image 2 de 3 Asus Chromebook C523N Keyboard Replacement: étape 13, image 3 de 3
    • Using a spudger, disconnect the two side-by-side ribbon cables from their connectors, pushing in the direction of the ribbons (toward the left side of the Chromebook).
  14. Asus Chromebook C523N Keyboard Replacement: étape 14, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 14, image 2 de 2
    • Disconnect the thick blue ribbon cable from the connector by pulling it away from the motherboard.
  15. Asus Chromebook C523N Keyboard Replacement: étape 15, image 1 de 3 Asus Chromebook C523N Keyboard Replacement: étape 15, image 2 de 3 Asus Chromebook C523N Keyboard Replacement: étape 15, image 3 de 3
    • Remove the 0.4mm JIS #0 screws from the heat sink in the center of the motherboard.
    • Lift and remove the heat sink.
  16. Asus Chromebook C523N Keyboard Replacement: étape 16, image 1 de 3 Asus Chromebook C523N Keyboard Replacement: étape 16, image 2 de 3 Asus Chromebook C523N Keyboard Replacement: étape 16, image 3 de 3
    • Gripping the thin white ribbon cable, gently pull it away from the motherboard to disconnect.
  17. Asus Chromebook C523N Keyboard Replacement: étape 17, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 17, image 2 de 2
    • Disconnect the thick black connector by gently pulling it up, away from the motherboard.
  18. Asus Chromebook C523N Keyboard Replacement: étape 18, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 18, image 2 de 2
    • Remove the two 0.4mm JIS #00 screws at the bottom of the hinge (closest to the motherboard).
    • Using an opening tool, pry the hinge upward.
  19. Asus Chromebook C523N Keyboard Replacement: étape 19, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 19, image 2 de 2
    • Remove the two 0.4 mm JIS #00 screws from the motherboard.
    • Gently lift and remove the motherboard.
  20. Asus Chromebook C523N Keyboard Replacement, Touchpad: étape 20, image 1 de 1
    • Pull gently on the touchpad cable connector to disconnect.
  21. Asus Chromebook C523N Keyboard Replacement: étape 21, image 1 de 1
    • Carefully, remove the tape from the touch pad only.
  22. Asus Chromebook C523N Keyboard Replacement: étape 22, image 1 de 1
    • Remove the three 1.4 mm JIS #00 screws.
  23. Asus Chromebook C523N Keyboard Replacement: étape 23, image 1 de 2 Asus Chromebook C523N Keyboard Replacement: étape 23, image 2 de 2
    • Lift at the far edge of the touchpad to remove it.
  24. Asus Chromebook C523N Keyboard Replacement, Keyboard: étape 24, image 1 de 2 Asus Chromebook C523N Keyboard Replacement, Keyboard: étape 24, image 2 de 2
    • Disconnect the two ribbon cables from the daughterboard.
  25. Asus Chromebook C523N Keyboard Replacement: étape 25, image 1 de 1
    • Remove the four 0.4mm JIS #00 screws from the daughterboard.
    • Remove the daughterboard.
  26. Asus Chromebook C523N Keyboard Replacement: étape 26, image 1 de 1
    • Remove the two 0.4mm JIS #00 screws on the left hinge.
  27. Asus Chromebook C523N Keyboard Replacement: étape 27, image 1 de 1
    • Lift the keyboard of the Chromebook off of the screen.
2 autres ont terminé cette réparation.
Aaron Hogan
Membre depuis le 10/15/19
682 Réputation
4 tutoriels rédigés
3 commentaires
Great walk through. I used this to replace a keyboard on a C423N ASUS. Everything but the track pad connector on the mother board and three screws instead of 2 on the screen hinges is the same.
Charles Stanley - Réponse
Hi there
How would I replace the screen for this model??
Saif - Réponse
how to replace ssd in motherbord
Suresh dhakar - Réponse
Ajouter un commentaire
Nombre de vues :
Dernières 24 heures : 2
7 derniers jours : 12
30 derniers jours : 36
Total : 2,418
